T-R
Oct 01, 2021Aspirant
Orbi drops internet
Orbi drops internet (RBR20 Orbi AC2200 Tri-Band WiFi Router) Router Firmware Version V2.7.3.22
- Oct 01, 2021
Does the top ring turn on PINK when this happens?
Armor, Circle, Traffic Meter.Has a power off for 1 minute then back ON with the ISP modem and Orbi system been performed since last update?
Oct 01, 2021Guru - Experienced User
T-R
Thank you for the quick response. I have performed the suggestions you recommended, now I will wait to see if there are no internet drops.
(Has a power off for 1 minute then back ON with the ISP modem and Orbi system been performed since last update?
Has a factory reset and setup from scratch been performed since last FW update?)
Regards
- FURRYe38Oct 01, 2021Guru - Experienced User
