thebishop
Feb 01, 2017Apprentice
Orbi drops wifi for iPad Pro, iPhone 7 and Macbook Pro intermittently
Running 1.4.0.34 on both main Orbi and sattelite (main and sattelite are on different floors with wall between, perhaps 20-25 feet distance straight line). I generally have "5 bars" of Wifi on al...
- Jul 11, 2017
Hello Everyone
We have release firmware version 1.12.0.18 this firmware has fixes for disconnects and many more I posted the release notes below.
https://kb.netgear.com/000044171/RBR50-Firmware-Version-1-12-0-18
If you are still having issues after updating your Orbi unit you may want to factory reset the Orbi and test again. If you are still having disconnect issues or other issues with this firmware please create a new thread or contact our support team.
http://www.netgear.com/support/contact.aspx
Thanks
DarrenM
Tingyunliu
Feb 16, 2017Star
I have exactly the same issue. I think the drop is from the satellite, but I really don't know what happened. I was quite happy when I first saw the fast speed, then it's quite frustrating seeing the disconnect to my I devices. I'd very much appreciate if Netgear support can reply here and let us know that they are aware of this issue and something is being fixed. Or I should just return the machine?
