thebishop
Feb 01, 2017Apprentice
Orbi drops wifi for iPad Pro, iPhone 7 and Macbook Pro intermittently
Running 1.4.0.34 on both main Orbi and sattelite (main and sattelite are on different floors with wall between, perhaps 20-25 feet distance straight line). I generally have "5 bars" of Wifi on al...
- Jul 11, 2017
Hello Everyone
We have release firmware version 1.12.0.18 this firmware has fixes for disconnects and many more I posted the release notes below.
https://kb.netgear.com/000044171/RBR50-Firmware-Version-1-12-0-18
If you are still having issues after updating your Orbi unit you may want to factory reset the Orbi and test again. If you are still having disconnect issues or other issues with this firmware please create a new thread or contact our support team.
http://www.netgear.com/support/contact.aspx
Thanks
DarrenM
genobkk
Feb 17, 2017Star
Even worse on my note 3 constantly dropping. wifi drops out no bars totally disconnects then back again and yes it does it on iPad or, iPhone 7 plus just note 3 is much worse. Really sorry I bought the thing, yes it get great wifi over my place but it does not work properly. I have to reboot whole systems every few days no internet at all but base unit now showing disconnected plus if you manually input DNS sometimes this will cause the internet not to work at all. It is a very buggy system, not worth the money. I have been using for a few months and no firmware update that fixed any of these issues, it looks like a much deeper issue with this device that adviously was rushed to market before it was ready. If I could get my money back I would return it
