thebishop
Feb 01, 2017Apprentice
Orbi drops wifi for iPad Pro, iPhone 7 and Macbook Pro intermittently
Running 1.4.0.34 on both main Orbi and sattelite (main and sattelite are on different floors with wall between, perhaps 20-25 feet distance straight line). I generally have "5 bars" of Wifi on al...
- Jul 11, 2017
Hello Everyone
We have release firmware version 1.12.0.18 this firmware has fixes for disconnects and many more I posted the release notes below.
https://kb.netgear.com/000044171/RBR50-Firmware-Version-1-12-0-18
If you are still having issues after updating your Orbi unit you may want to factory reset the Orbi and test again. If you are still having disconnect issues or other issues with this firmware please create a new thread or contact our support team.
http://www.netgear.com/support/contact.aspx
Thanks
DarrenM
Anonymous
Feb 20, 2017It's a known issue in Netgears firmware which they say they are working on to fix. They been collecting logs from mine and a few other peoples devices. It drops our iOS devices (iphone 7s, ipads) and Android devices (Samsung S7 Edge, LG V20).
thebishop
Feb 20, 2017Apprentice
I tried moving the sattelit as far as possible, but still dropping (possibly not as often though).
killabandit, thanks, if that is the case there is still hope ;-) I just want to state it also drops for macOS Macbook Pro laptops, not only mobile devices. Lets see how the next firmware works out. Anyone who knows approximately the cadence of new updates?
To Netgear Engineering: I would be happy to both provide additional debug logs and/or try out beta firmware if you need external testers with reproducible fail cases.
