thebishop
Feb 01, 2017Apprentice
Orbi drops wifi for iPad Pro, iPhone 7 and Macbook Pro intermittently
Running 1.4.0.34 on both main Orbi and sattelite (main and sattelite are on different floors with wall between, perhaps 20-25 feet distance straight line). I generally have "5 bars" of Wifi on al...
- Jul 11, 2017
Hello Everyone
We have release firmware version 1.12.0.18 this firmware has fixes for disconnects and many more I posted the release notes below.
https://kb.netgear.com/000044171/RBR50-Firmware-Version-1-12-0-18
If you are still having issues after updating your Orbi unit you may want to factory reset the Orbi and test again. If you are still having disconnect issues or other issues with this firmware please create a new thread or contact our support team.
http://www.netgear.com/support/contact.aspx
Thanks
DarrenM
JMU1998
May 21, 2017Luminary
Anyone using Beta Firmware seen any improvement for this issue regarding iOS devices randomly dropping connection?
wchp
May 22, 2017Luminary
Just got this:
"We recently released an official Firmware for ORBI and it does not include wireless disconnection fixes for iOS yet as we are still working to make sure we do not miss anything on the fix to be embedded on the next official Firmware.
We got a new beta Firmware you can load to your unit in case your devices auto updated to the latest. Please use the links below:
Please let us know how your devices respond with this Firmware and thank you for your continued patience and for working with us on this. Have a great day always."
- loomis1975May 22, 2017Luminary
Both links download the exact same sized file with the exact same name "RBR50" I'd be hesitant to upload one of those to your RBS50 Satellite. It might bork it.
- wchpMay 22, 2017Luminary
I was notified that I shouldn't have posted the links, that they are only to be handed out by the support group. The links do in fact download two different files (labeled RBR and one labeled RBS) but again, they are beta debug and caused more problems than they solved. I notified support of my experience and hopefully, it will be accounted for in the next release.
- goswhMay 30, 2017Tutor
Hi, Did you ever share the links so we can download the beta and try this as well?
--Shawn
