thebishop
Feb 01, 2017Apprentice
Orbi drops wifi for iPad Pro, iPhone 7 and Macbook Pro intermittently
Running 1.4.0.34 on both main Orbi and sattelite (main and sattelite are on different floors with wall between, perhaps 20-25 feet distance straight line). I generally have "5 bars" of Wifi on al...
- Jul 11, 2017
Hello Everyone
We have release firmware version 1.12.0.18 this firmware has fixes for disconnects and many more I posted the release notes below.
https://kb.netgear.com/000044171/RBR50-Firmware-Version-1-12-0-18
If you are still having issues after updating your Orbi unit you may want to factory reset the Orbi and test again. If you are still having disconnect issues or other issues with this firmware please create a new thread or contact our support team.
http://www.netgear.com/support/contact.aspx
Thanks
DarrenM
Retired_Member
Jun 03, 2017Yes it is all devices not just Apple devices. The actual connection is dropping on all of them, some devices just take longer to reconnect which makes it noticeable.
wchp
Jun 03, 2017Luminary
While we wait for Netgear to sort this out I have put my backup router into service.
Below is the signal graph for the Orbi RBR/S50 (L8-Holyoke) and the R6900 (TwoAchers) behind it.
