thebishop
Feb 01, 2017Apprentice
Orbi drops wifi for iPad Pro, iPhone 7 and Macbook Pro intermittently
Running 1.4.0.34 on both main Orbi and sattelite (main and sattelite are on different floors with wall between, perhaps 20-25 feet distance straight line). I generally have "5 bars" of Wifi on al...
- Jul 11, 2017
Hello Everyone
We have release firmware version 1.12.0.18 this firmware has fixes for disconnects and many more I posted the release notes below.
https://kb.netgear.com/000044171/RBR50-Firmware-Version-1-12-0-18
If you are still having issues after updating your Orbi unit you may want to factory reset the Orbi and test again. If you are still having disconnect issues or other issues with this firmware please create a new thread or contact our support team.
http://www.netgear.com/support/contact.aspx
Thanks
DarrenM
Retired_Member
Jun 06, 2017Thanks machinelearner. Would you mind checking your backhaul signal and posting the results? It would be very helpful to see how it looks for a user who is not having these issues.
If there's one thing I have learned in all of this, it's to check product forums first before buying any tech product.
- MachineLearnerJun 06, 2017Apprentice
Sorry, I have no idea how to do that. Sounds like I need some software I don't have.
- ryman982Jun 07, 2017Tutor
Sounds like there is a beta patch for the RB50 but nothing for the other models... Unfortunately, my Orbi is back in the box and being returned.
