thebishop
Feb 01, 2017Apprentice
Orbi drops wifi for iPad Pro, iPhone 7 and Macbook Pro intermittently
Running 1.4.0.34 on both main Orbi and sattelite (main and sattelite are on different floors with wall between, perhaps 20-25 feet distance straight line). I generally have "5 bars" of Wifi on al...
- Jul 11, 2017
Hello Everyone
We have release firmware version 1.12.0.18 this firmware has fixes for disconnects and many more I posted the release notes below.
https://kb.netgear.com/000044171/RBR50-Firmware-Version-1-12-0-18
If you are still having issues after updating your Orbi unit you may want to factory reset the Orbi and test again. If you are still having disconnect issues or other issues with this firmware please create a new thread or contact our support team.
http://www.netgear.com/support/contact.aspx
Thanks
DarrenM
st_shaw
Jun 14, 2017Master
Two MacBook Pros, iPad, iPhones, Android, Sonos, Rasperry Pi's, etc. here. Zero problems with Orbi.
MachineLearner
Jun 14, 2017Apprentice
Full range of Apple devices here, and no problems with Orbi. Better performance than previous Airport Extreme routers. We keep Apple devices on current versions of OS, which I highly recommend. Some Nest products and other IoT devices seem to have issues, especially older versions of these products.
