thebishop
Feb 01, 2017Apprentice
Orbi drops wifi for iPad Pro, iPhone 7 and Macbook Pro intermittently
Running 1.4.0.34 on both main Orbi and sattelite (main and sattelite are on different floors with wall between, perhaps 20-25 feet distance straight line). I generally have "5 bars" of Wifi on al...
- Jul 11, 2017
Hello Everyone
We have release firmware version 1.12.0.18 this firmware has fixes for disconnects and many more I posted the release notes below.
https://kb.netgear.com/000044171/RBR50-Firmware-Version-1-12-0-18
If you are still having issues after updating your Orbi unit you may want to factory reset the Orbi and test again. If you are still having disconnect issues or other issues with this firmware please create a new thread or contact our support team.
http://www.netgear.com/support/contact.aspx
Thanks
DarrenM
dodgeitri
Jun 25, 2017Aspirant
I've tried that, you're just going to run into the same issue in different locations. I tested it in my old router by setting up matching SSIDs, it has a roaming feature that would fix it but it's easier to just have separate IDs. I also like knowing what's connected to what.... I don't want my firetv to connect to 2.4 because it's slightly stronger than 5 based on its location.
DarrenM
Jul 11, 2017Sr. NETGEAR Moderator
Hello Everyone
Thanks
DarrenM
