Dsieber
Oct 30, 2019Aspirant
Orbi drops wifi network - RBR50
Hi everyone, So, I have an Orbi RBR50 running firmware v2.5.0.38. It's great - when it works. The problem - the main WiFi network keeps just disappearing. It will vanish for about 30 seconds, the...
Oct 30, 2019Guru - Experienced User
What is the Mfr and model# of the ethernet switch in the configuration?
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Dsieber wrote:Hi everyone,
So, I have an Orbi RBR50 running firmware v2.5.0.38. It's great - when it works. The problem - the main WiFi network keeps just disappearing. It will vanish for about 30 seconds, then come back again. Ie, looking at the WiFi network list, it doesn't even appear. This is on multiple devices.this happens at random intervals. Sometimes it's fine for hours, sometimes it happens multiple times in an hour. Just happened again while trying to post this.
Any suggestions/ideas?
Thanks,
Dirk
Dsieber
Oct 31, 2019Aspirant
Hi,
Let me see if I can answer at least most of these right now.
1) Firmware - as I said originally, it's v2.5.038
2) No other ethernet switch present - cable modem straight to Orbi router.
3) House size - about 5000 sq ft
4) Distance between router & satellite - 2 stories vertically, about 20ish feet horizontally across that distance??
5) 2.4 Ghz currently set to auto, 5 is on channel 48.
6) 6 other wifi networks from neighbours show up on a scan.
7) Beamforming was on. I've enabled MIMO. WMM was also already on.
8) I'll try disabling the other items you list & rebooting when it's outside my work day. ;)
For what it's worth - it seems to be wifi-only. I have a couple of computers hard-cabled to the satellite, and their connetions appear quite stable.
Oh, and yes, I'll try to grab a log file as well.
Thanks!
Dirk
