glojoe
Sep 28, 2019Tutor
ORBI dual band router and Simplisafe doorbell?
I have the ORBI RBR20 router and I am trying to connect a Simplisafe doorbell which requires 2.4 Ghtz but it can't connect. The setup never gives me the chance to choose which band to connect to. Any...
CrimpOn
Sep 29, 2019Guru - Experienced User
So the Simplisafe app created a QR code. Held the QR code in front of the camera. Then, the Simplisafe app did not recognize that the camera was there?
glojoe
Sep 30, 2019Tutor
Yes, I scanned the QR code, it automatically, without me signing in, searches for WiFi for a couple minutes and then stops. It's like it times out because it can't find the 2.4 band and it goes back to blinking white. The SimpliSafe CS said that it should ask me to select the WiFi I want to connect to but it never does that step in the setup process.
- CrimpOnSep 30, 2019Guru - Experienced User
glojoe wrote:
Yes, I scanned the QR code, it automatically, without me signing in, searches for WiFi for a couple minutes and then stops. It's like it times out because it can't find the 2.4 band and it goes back to blinking white. The SimpliSafe CS said that it should ask me to select the WiFi I want to connect to but it never does that step in the setup process.I have Simplisafe and use the Simplisafe app on both my phone and tablet (they are both Android). I went through the camera setup on both the phone and the tablet. It shows a list of WiFi networks. I select the one I want. It asks me to enter the password. It asks if the light it blinking white. It asks if this is the front door or back door. And THEN it asks me to hold the QR code in front of the camera. I had to quit then because I have not purchased a camera.
Yes, there was that ominous message about "Must be 2.4G" when the list of networks was displayed.
Questions:
- Using Apple or Android?
- The instructions include a QR code, but that is only to load the Simplisafe app. The QR code to display in front of the camera appears on the phone or tablet. If you did not reach that step, then something is definitely wrong.
