mgeorgy
Dec 15, 2017Tutor
Orbi Ethernet Backhaul causing broadcast storm
I have just upgraded my Orbi router and satellites to V2.1.1.12 hoping to take advantage of the recent Ethernet backhaul feature. I use the Orbi router as my main router with a 24 port switch servic...
mgeorgy
Dec 18, 2017Tutor
I spent a day this weekend trying every possible configuration, I factory reset the router and satellites several times, attempted connecting the satellites directly to the router via ethernet and in every scenario the satellites worked at first but upon any changes to the router reconfiguration that seemingly required a reboot (DHCP Reservation, Custom DNS Server, etc) the packet storm would ensue.
I've temporarily given up on the Ethernet backhaul and have started shopping for an entirely new networking solution to replace the Orbi.
swanny76
Jan 07, 2018Tutor
I am having this same issue. After updating my router and satellite firmware. I tried setting up ethernet backhaul and it crashed my entire network as well. On 3 separate attempts, the outcomes were the same. Had to reboot my modem and router to get internet back. Hope this addressed in a future update as ethernet backhaul was a feature I really wanted to use. I still have about 25 days in my return window so maybe I will explore alternatives as well.
- tcommanderJan 07, 2018Guideswanny76 how many satellites do you have?
- swanny76Jan 07, 2018TutorJust one for now. I just bought the system but will need to add a second if I keep the system. Thanks
- lowepgJan 07, 2018Apprentice
Curious, why would you opt for wired backhaul for this system? One of its most unique features (wgot which we paid a premium!) is the dedicated wireless backhaul.
If I had cat6 connecting all my satelites- there's no way in hell Id be using this system. You could very easily plug in wifi access points and take advantage of some kickass (and bulletproof) hardware from companies like Ubiquity, etc.
