mgeorgy
Dec 15, 2017Tutor
Orbi Ethernet Backhaul causing broadcast storm
I have just upgraded my Orbi router and satellites to V2.1.1.12 hoping to take advantage of the recent Ethernet backhaul feature. I use the Orbi router as my main router with a 24 port switch servic...
BDubUT
Jun 06, 2018Aspirant
Everytime I've tried using the WAN port with wired backhaul, it hasn't worked; 2.1.4.16 included.
I opened a support case with Netgear and they seemed to indicate that it should and gave me instructions to factory reset and rebuild in AP mode, however that didn't prove successful.
Also, I spoke too soon on the ethernet backhaul. I should point out on caveat. My old Orbi system consists of an RBR50 and 2x RBW30's. My whole purpose in using wired backhaul and buying a RBK23 is that I recently finished terminating all my low voltage and wanted to make use of it. After finishing my testing, I moved my RBS20's to their final location, my RBW30's still plugged in. When one of the RBS20's came up, instead of connecting to the RBR50, it connected to a RBW30's. Since the satellites don't seem to run spanning-tree, it created a loop. I quickly realized what was happening and disconnected my RBW30's, which solved the problem.
I'm going to try disabling daisy-chaining, which should resolve this issue. If you're running wired backhaul, there shouldn't be a reason for it in the first place.
lowepg
Jun 06, 2018Apprentice
Honestly, if you're running wired backhaul- THIS is the wrong product for you in the first place.
If all my satelites could be hardwired- I'd be in heaven- and sure as hell NOT using this crap. I'd be running Ubuity APs and never looking back at another Netgear product again.
- BDubUTJun 06, 2018Aspirant
Heh, straight up access points would definitely make more sense. When we built our home 3 years ago, it didn't even cross my mind to run any CAT6 in the ceiling. I've got 18 CAT6 runs in my house, but none in the ceiling. Being a network engineer by trade, I should've had more foresight.
Ubiquiti access points are meant to be ceiling mounted, not sit on a table. My problem is there aren't really a lot of table top access points. These "mesh" systems are really the second best option.
- st_shawJun 06, 2018Master
I have Ubiquiti access points in my main house. They work perfectly fine placed upside down on top of wooden furniture. Two APs cover inside the house and the yard. I was able to run wires in that house. I can't run wires in the house where I have Orbi. That's why I have Orbi there. :)
Looking again, it looks like the Netgear WAC505 might fight the bill. Does anyone have any experience with them? I know people have a love/hate relationship with Insight, but is a cloud "controller" really needed for 2-3 APs?
