JayMan7
Jan 14, 2019Initiate
Orbi Ethernet Backhaul showing connected as 5G
Just purchased the RBK23; set-up as AP mode with FiOS. WiFi is working, and have the Satellites connected via GigEthernet, but they are showing connected with 5G on the web interface. Also, devices ...
Jan 14, 2019Guru - Experienced User
What FW is currently loaded?
Is the Orbi system operating in Router or AP mode?
What is the Mfr and model# of the ethernet switch if one is in the configuration.
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
Daisy Chain, Save settings and reboot the router and satellite(s).
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually.
For wired back haul:
Set up IP address reservations for each satellite and devices on the router as you add them to the router. The satellites need to be set up via wireless first. Then connect 1 satellite at a time to the ethernet LAN cable. Wait 5 minutes and the top led on the satellite should turn on BLUE. Set up an IP address reservation for the 1st satellite. Continue to do the same thing for the 2nd satellite. Then follow up with your devices.
- JayMan7Jan 14, 2019Initiate
Messing around with this some more this afternoon, I moved the connection on the Orbi router from Internet to LAN, and now the web GUI shows how and where and how each wireless device is connected, as well as both Sats showing as wired. The ios app also shows the satellites connected as wired.
However, after moving to the LAN port, the ios app would show no internet connection, and the router itself had the magenta light on.
As a test, I changed the wiring so everything goes through the Orbi Router, the magenta light went out, and the app shows internet connection.
[FiOS_Router] <-> [WAN/Orbi Router/LAN] <-> [Switch] <-> [Orbi Sat]
I had previously specified an IP address for the Orbi-Router, but have not seen where to perform this for the Satellites. Where is that configured?
Thanks,
JayMan
- FURRYe38Jan 15, 2019Guru - Experienced User
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopIf your using the FIOS router then you would specify IP addresses here for the Orbi router and satellites in AP mode. If your using the Orbi router in router mode, then you specify IP addresses for the satellite(s) on the Orbi router under Advanced Tab/LAN Setup.
I recommend you try option #2 with your Orbi system since you have a router in front of the Orbi router.
Thanks,
JayMan
- Chuck_MJan 15, 2019Mentor
There is no direct place to do that in the configuration, but it can be done:
The method I used was "reserve an IP address" based upon the satellite's MAC address.
As a matter of technique... I have my DHCP issuing IP addresses at 192.168.1.20
You can reserve IP addresses below the DHCP starting threshold.
So I reserved 192.168.1.5 and 192.168.1.6 for my two satellites placing them logically between the router (191.168.1.1) and all of the other devices (which begin at 20.)
This technique makes readability and understanding much easier of your logical network environment.
As a sidenote, I also "banded" like devices in reserved IP ranges. (e.g. put speakers from 50-80, TVs from 100-110, household devices between 30-50, etc. I think that is a pretty good technique for complex network environments.
- oscarfMar 07, 2019Aspirant
Thanks for the tip. I was just seeing the same thing between a RBR50 and RBS50 connected over Ethernet using a separate siwtch. Interestingly, wireless devices that were connected to the satellite showed up as "wired" to the Orbi router, which makes sense. So I don't know if the Orbi router and satellite were *really* using wireless for the backhaul, or if they were actually talking over Ethernet and this is just a display bug in the firmware.
- FURRYe38Mar 08, 2019Guru - Experienced User
When the satellite is connectd via wire to the base, any devices connected to the satellite will be detected as wired connection, even though they are wirelessly connected to the satellite. The tunnel on which the detection performs will determine how devices are reported. In this case if wired, devices will showup as wired instead of wireless.
Some switches may effect how the satellite operates as well. Managed and Green Ethernet switches are not recommended for use with Orbi systems.
Also new FW has corrected issues seen with ethernet backhaul in prior versions. Something to review and try.
