JayMan7
Jan 14, 2019Initiate
Orbi Ethernet Backhaul showing connected as 5G
Just purchased the RBK23; set-up as AP mode with FiOS. WiFi is working, and have the Satellites connected via GigEthernet, but they are showing connected with 5G on the web interface. Also, devices ...
ekhalil
Jan 14, 2019Master
JayMan7 wrote:
For what its worth, on the iOS App, neither Sat is showing as a Satellite, just as a connected device.
Both are identified in the diagram, and both have the magenta "dot".
It seems that your satellites are not correctly synced with the router. Please use a paperclip to reset your satellites as follows:
- Make sure your Orbi device is powered on.
- Using a paper clip or similar object, press and hold the Reset button until the Power LED on your Orbi device blinks amber. Note: If you're resetting a wall plug satellite, the ring LED blinks amber. Your Orbi device is reset.
Then sync them again by pressing the sync button on the router and satellites, one by one.
