mark8par
Aug 04, 2017Star
Orbi ethernet backhaul
Sorry I know its been asked many times, but
Will Orbi support ethernet backhaul to satellite at any point?
I have ethernet cabling from the fron to back of house and I believe this would take some of the workload from the main unit. I do need converage upstairs in the house in some deadspots but have no ethernet there.
The reason I want to run this way is becuse the network can get a little overloaded at times, with many devices, streaming etc. I have tried many combinations of router and access point and all seem to struggle in some way or another.
- DarrenMSr. NETGEAR Moderator
Hello mark8par
Yes that is a feature that is coming I do not have a ETA on it.
DarrenM
- Juan11Initiate
Darren, been reading about the backhaul subject and there're posts 1.5 years old; so it's time for a "timescale" commitment from Netgear.
i just moved to Orbi after an extremely painful experience with Velop and I'm very pleased so far. Please keep it better.
I couldnt wait and in the end decided to purchase the Amplifi HD and I must say its very very good upto now.
- BobAceAspirant
Hello, I hopethis helps at home I have RBR50 as my router RBS50 as Wireless and I have just added RBS40 via one of the ethernet port and all devices have firmware 2.1.1.16 and they work great using Ethernet connection.
Thank you
- ThoOomAspirant
Hi,
is there ethernet backhaul yes or no ? I currently have 3 wifi standalone networks to cover my place which is a mess to setup/support. I'd like to plug one single big wifi network but cannot afford traffic to be polluted by satellite and routers working together using the wifi. Can we be sure that they now talk using ethernet port (my place is wired everywhere from the wall ethernet cat-6 cables, wifi is to reach endpoints like smartphone, tablets, laptop computers).
I'm looking for pro version SRK60 and 2 satellites SRS60.
Thx for your help
- st_shawMaster
wrote:
Hi,
Thx for your help
Why would you use a wireless mesh system like Orbi if your whole place is wired? A set of managed wired access points would be a better solution. Netgear sells them, as do other manufacturers.
