Showguy
Jul 11, 2018Virtuoso
Orbi ethernet backhaul
Hi I just installed Ethernet backhaul to my system. Everything seems to be working fine except when I go to see what devices are connected to the satilite it shows none. My firmware is up to date and ...
Jul 12, 2018Guru - Experienced User
What is connected to the satellite?
Any wireless and wired devices?
What browser are you using when you access the satellites web page? Does it happen with IE11 or FF or Opera browsers?
Showguy
Jul 12, 2018Virtuoso
Thanks for the reply. I was seeing nothing on the satilite on the Orbi admin page or the app. However I checked about an hour after I did the backhaul and everything started to populate on the satilite. All seems good. Thanks again.
- FURRYe38Jul 12, 2018Guru - Experienced User
Ya may be a timing issue and just need to wait for things to populate.
Enjoy. :smileywink:
