NeilNavin
Mar 15, 2020Follower
Orbi Ethernet Backhaul
I currently have a part of my house that is wired with cat cable (ethernet). I would like to know if I can backhaul from one satellite (RBS20) to another without the subsequent backhaul to the hub? ...
Mar 15, 2020Guru - Experienced User
Yes:
You may need to disable Daisy Chain if something doesn't work...
Be sure to use non manged and non green ethernet switches.
