flatfoot139
Sep 14, 2020Follower
Orbi Ethernet Backhaul
Hello, I have the Orbi RBR40 router with 1 satelitte that is currently connected through wifi. The Satelitte is not getting a strong signal due to the layout of the house (concrete, walls etc...). ...
Sep 14, 2020Guru - Experienced User
flatfoot139 wrote:Hello, I have the Orbi RBR40 router with 1 satelitte that is currently connected through wifi. The Satelitte is not getting a strong signal due to the layout of the house (concrete, walls etc...). I attempted to move it to a different location and the weak signal continued. The satelitte is in a part of the house where extended range is needed. Would hardwiring the satelitte from the router improve the satelitte's signal?
