hackwright
May 13, 2020Tutor
Orbi Ethernet Backhaul/Compatible Switches
I've been (unsuccessfully) trying to setup my ethernet backhaul between my Orbi RBR50 and RBS50 and have recently stumbled across a decent number of conversations/posts describing the woes of Orbi's ...
hackwright
May 17, 2020Tutor
In addition to the multiple "magenta" issues spawned last night and again at 1:30 this morning (I have no evidence this is related to the Tenda switches -- just assumptions), I also discovered that my wired LAN was only getting 8-10 mbps. My bad -- I was so excited that everything was connected and the RBR50 admin console reported "wired" for backhaul, I never bothered to test performance until this morning. So although this approach seems to have "solved" the ethernet backhaul issue, the combination of a new round of network crashes coupled with a continuous throttling of my WIRED network (and for any wireless connection via the RBS50), I decided to remove the Tenda switches. I immediately got back to my "normal" wired throughput at the expense of my ethernet backhaul (which is now back to 5G connection type/good status). <sigh>
I'm going to sit on this approach for a bit to make sure my "magenta" lights issue stabilizes now that those big, mean Tenda switches aren't bullying my NetGear network and will independently see how well those Tenda switches work with other routers/network infrastructure. Hint: I'll be willing to bet they'll do just fine.
As mentioned before, my disappointment with these Orbi's runs quite deep. I purchased them for the ethernet backhaul and that seems to be a pipe dream. The Orbi design/engineering overall seems very interesting but the implementation similarly seems way too fragile.
I'm always making changes to my network (bringing in new devices, extending it as needed via switches) and I can't go through this RIDICULOUS amount of effort and downtime every time I touch it. I buy NetGear equipment because I want to be able to install it, get good performance (perhaps not the best, but still decent) and then mostly forget it (not counting quick log scans and checking for updates).
hackwright
May 20, 2020Tutor
Quick update. Due to other issues I'm having with my RBR50v2, I've re-introduced a new primary router (a Nighthawk X6S AC4000 the Orbi was meant to replace). The RBR50 is now only providing WiFi in AP/Bridge mode and no longer has any responsibility for my wired network and no direct communication with the Internet (i.e., that's all handled by the Nighthawk).
I have not yet tried to establish ethernet backhaul with this setup as I'm waiting for things to "settle" and am still monitoring the RBR50's performance (have had numerous "crashes").
To rub a bit of salt in the wound, NetGear support closed the ticket I raised to find the list of compatible switches without any discussion with me, calling it a "duplicate ticket" (of course, the ticket they identified as "duplicate" was the one I raised where I was finding unrecognized/wired devices on my Orbi's list of Attached Devices, which is the main reason the RBR50 is no longer my primary router and won't ever have direct contact with the Internet). I explained to NetGear support this morning that the two tickets are completely unrelated and they told me they'd "escalate". So I've not only made no progress in getting that list of "certified" switches in support of ethernet backhaul, I've actually taken a step backwards...
If anyone else would like to try to get that "certified switches" list from NetGear, feel free...
- FURRYe38May 20, 2020Guru - Experienced User
Not sure if there is a list of switches that NG has. Possible.
I know that D-Link DGS-105/108 and HP ProCurve 1400-1800 series switches work with Orbi. - GMoGoody8Jul 22, 2020Luminary
FURRYe38 , It looks like D-Link has introduced a new revision(REVC6) that now supports 802.3az :(
https://us.dlink.com/en/products/dgs-108-8-port-unmanaged-gigabit-metal-desktop-switch
This now potentially only leaves the Tendra and HP ProCurve. - FURRYe38Jul 22, 2020Guru - Experienced User
Ok. Thanks for letting us know. I was curious if there had been any followon Revs. I'll look at mine and see what they are. They are about 3-4 years old I believe. I guess if you can find the pro curves 1400-1800 series, these will work fine.
GMoGoody8 wrote:FURRYe38 , It looks like D-Link has introduced a new revision(REVC6) that now supports 802.3az :(
This now potentially only leaves the Tendra and HP ProCurve. - GMoGoody8Jul 22, 2020Luminary
Np, Thought I'd mention it. I have been lurking on this thread because I can't utilize ethernet backhaul right now but I am moving soon and my setup will be similar as the OP where the garage has the in wall ethernet drops and didn't want to have my modem and router or satellite in such a confined space. So then I was contemplating replacing my Netgear gs108v3 gs108v4, and gs105NA for the ones recommended in here but now I may just hope a pray a firmware update fixes this 802.3az compatibility issue, or depending on the location of the garage drop cabinet drilling into the closet on the other side if that's the wall they put it on.
You'll have to try the GS series and see if they work out for you. I may put my D-Link DGS ones back online and check again.
I just swapped out my HP Procurves for my D-Link DGS 108 and 105s. 108 is a Rev B and the 105s are Rev Cs.
Up and running. Thought I was concerned after connecting the RBS50 at the last conection. The network started constantly ARPg for about a good minute to1:30. I Thought I might have to reboot the RBR however when I went back up stairs, I noticed the switch in the living room wan't constantly blinking thus the network seemed to settle back down. It now working normally.
Nice, You have a backup if need too.
Sucks D-Link DGS 108 revision changed. Maybe I can find a retailer that might have a few revision Bs or even better NG fixing this on the Orbi itself - FURRYe38Jul 22, 2020Guru - Experienced User
Very possible. Might ask the retailer if you find one about Rev Info.
- tomschmidtJul 22, 2020Virtuoso
Netgear really needs to fix this so that green network switches work on the wired backhaul of the Orbi. Netgear does not even offer a current model of a network switch without the green 802.3az feature. My Netgear GS116v1 is about 4 years old and does not have 802.3az built in, so it works. But newer versions do not work since the green features are now standard.
Adding Blanca_O to escalate.
Yes, would be nice for Orbi AC and AX.
