Seattlites's avatar
Seattlites
Orbi Ethernet connections LAN 1 and LAN 3 deliver 100Mbps while LAN 2 delivers 1Gbps
Any thoughts on why ethernet cable LAN 2 delivers my actual 1Gbps connection speed while LAN 1 and LAN 3 only deliver 100Mbps?  All wired cables throughout home are CAT-7 installed three years ago.  ...
  • Seattlites's avatar
    Seattlites
    Dec 23, 2019
    CrimpOn, thanks for replying.
    I identified the problem testing from the same patch cable connected to each ethernet port in the wall to my laptop.  Doesn't matter what cable I use to connect from the wall ports.  I always end up with 100Mbps for LAN 1 and LAN 3 and 1Gbps from LAN 2.
    I went directly to the router and plugged in a short 3' gigabit capable patch cable to each LAN port and now I see 1Gbps connection speeds from each.
    I will not even pretend to understand how CAT-7 cables that were all installed from the same spool could deliver different speeds, but this is clearly not an ORBI issue.
