Seattlites
Dec 23, 2019Aspirant
Orbi Ethernet connections LAN 1 and LAN 3 deliver 100Mbps while LAN 2 delivers 1Gbps
Any thoughts on why ethernet cable LAN 2 delivers my actual 1Gbps connection speed while LAN 1 and LAN 3 only deliver 100Mbps? All wired cables throughout home are CAT-7 installed three years ago. ...
- Dec 23, 2019
CrimpOn, thanks for replying.
I identified the problem testing from the same patch cable connected to each ethernet port in the wall to my laptop. Doesn't matter what cable I use to connect from the wall ports. I always end up with 100Mbps for LAN 1 and LAN 3 and 1Gbps from LAN 2.
I went directly to the router and plugged in a short 3' gigabit capable patch cable to each LAN port and now I see 1Gbps connection speeds from each.
I will not even pretend to understand how CAT-7 cables that were all installed from the same spool could deliver different speeds, but this is clearly not an ORBI issue.
CrimpOn
Dec 23, 2019Guru - Experienced User
I had a problem that one of my Orbi LAN ports showed as 100mb while the others were 1000mb. Turned out the patch cable was old. I have a huge box of ethernet cables and paid no attention when I set up some computers. Swapped out the cable and "all is well".
Even though the wiring inside the wall is Cat7, do you also have patch cables?
Seattlites
