MixMaster's avatar
MixMaster
Apprentice
Apr 18, 2021
Orbi Ethernet Half the Speed of WiFi
I have an Orbi Router and two Satellites working pretty well but just noticed an issue with one of the Satellites.   I have a PC plugged into a Satellite via Ethernet which consistently gets downlo...
  • FURRYe38's avatar
    Apr 19, 2021
    Does the PC get good speeds if connected at the RBR?
    Does a different PC experience same thing at RBS?
    Be sure the PCs ethernet adapter drivers are up to date.
