MixMaster
Apr 18, 2021Apprentice
Orbi Ethernet Half the Speed of WiFi
I have an Orbi Router and two Satellites working pretty well but just noticed an issue with one of the Satellites. I have a PC plugged into a Satellite via Ethernet which consistently gets downlo...
- Apr 19, 2021
Does the PC get good speeds if connected at the RBR?
Does a different PC experience same thing at RBS?
Be sure the PCs ethernet adapter drivers are up to date.
Apr 19, 2021Guru - Experienced User
MixMaster
Apr 20, 2021Apprentice
Thanks for the reply. I just tried that and it's looking more like a notebook NIC driver issue. This is my wife's work computer and their IT department locks down end-user installations but it's my guess that they haven't updated manufacturer (Lenovo) driver updates. The speeds on the RBR were the same both for wired and Wireless. I'll be opening up a ticket with their support.
I appreciater it!
- FURRYe38Apr 20, 2021Guru - Experienced User
Hopefully they can get updated. Good Luck.
:smileywink:
