silverdawn
Jul 01, 2018Aspirant
Orbi Ethernet ports
Hello,
I recently had Spectrum (Timewarner cable) come out to the house to adress network connectivity issues. I should be pulling in over 400Mbps and I am getting that through to my Arris SB6190 ...
silverdawn
My ethernet status on my WIN10 PC is also showing 1.0Gbps connection to the ethernet port on the Orbi.
varase
Jul 02, 2018Guide
I think what he's saying is not that the ethernet ports negotiate at a slower speed, but that he gets less bandwidth (actual data transfer speed) through the LAN ports than through wireless.
- silverdawnJul 03, 2018Aspirant
Correct, I am getting around 100Mbps through the ethernet ports and using Wireless AC I am getting 380Mbps. The ethernet ports should be pulling up to 1Gbps. I am not asking for that, but an external bandwidth test should at least be hitting 400+ when there are no physical restrictions going out which was proven with the other tests.
