j0ebeer
Jan 14, 2020Guide
Orbi excessive pinging
Does anyone else see their Orbi satellites doing excessing pings to the default gateway? In my firewall log I am getting thousand of them and I don't know why. Or where to disable it. Joe
Jul 13, 2020Guru - Experienced User
Somthiing to try for your self and see. I recommend a factory reset and setup from scratch. I would ping test with out the RBS and ALL other devices disconnected from the RBR. use just a wired PC to test with initially.
kwiebe wrote:V2.3.5.26 RBS20
I just noticed this too. Disturbing and it's not normal. This needs to be fixed.
Did it get fixed in 2.5.1.16?
kwiebe
Jul 13, 2020Aspirant
I was hoping to find out from someone already running the later firmware whether the ping behavior was still exhibited. Seems like a reasonable inquiry. Are you running the newer firmware FURRYe38?
- FURRYe38Jul 13, 2020Guru - Experienced User
- kwiebeJul 13, 2020Aspirant
OK great - does the ping behavior carry forward with the newer firmware?
Heres my ping with my mac book wirelessly connected pinging the RBR50:
PING 192.168.0.1 (192.168.0.1): 56 data bytes
64 bytes from 192.168.0.1: icmp_seq=0 ttl=64 time=21.581 ms
64 bytes from 192.168.0.1: icmp_seq=1 ttl=64 time=5.296 ms
64 bytes from 192.168.0.1: icmp_seq=2 ttl=64 time=7.785 ms
64 bytes from 192.168.0.1: icmp_seq=3 ttl=64 time=13.785 ms
64 bytes from 192.168.0.1: icmp_seq=4 ttl=64 time=16.978 ms
64 bytes from 192.168.0.1: icmp_seq=5 ttl=64 time=12.250 ms
64 bytes from 192.168.0.1: icmp_seq=6 ttl=64 time=10.974 ms
64 bytes from 192.168.0.1: icmp_seq=7 ttl=64 time=8.575 ms
64 bytes from 192.168.0.1: icmp_seq=8 ttl=64 time=12.546 ms
64 bytes from 192.168.0.1: icmp_seq=9 ttl=64 time=24.586 ms
64 bytes from 192.168.0.1: icmp_seq=10 ttl=64 time=7.343 ms
64 bytes from 192.168.0.1: icmp_seq=11 ttl=64 time=5.241 ms
64 bytes from 192.168.0.1: icmp_seq=12 ttl=64 time=4.750 ms
64 bytes from 192.168.0.1: icmp_seq=13 ttl=64 time=10.755 ms
64 bytes from 192.168.0.1: icmp_seq=14 ttl=64 time=13.280 ms
64 bytes from 192.168.0.1: icmp_seq=15 ttl=64 time=12.145 ms
64 bytes from 192.168.0.1: icmp_seq=16 ttl=64 time=12.212 ms
64 bytes from 192.168.0.1: icmp_seq=17 ttl=64 time=5.385 ms
64 bytes from 192.168.0.1: icmp_seq=18 ttl=64 time=11.898 ms
64 bytes from 192.168.0.1: icmp_seq=19 ttl=64 time=12.723 ms
64 bytes from 192.168.0.1: icmp_seq=20 ttl=64 time=13.254 ms
64 bytes from 192.168.0.1: icmp_seq=21 ttl=64 time=4.815 ms
64 bytes from 192.168.0.1: icmp_seq=22 ttl=64 time=6.125 ms
64 bytes from 192.168.0.1: icmp_seq=23 ttl=64 time=14.790 ms
64 bytes from 192.168.0.1: icmp_seq=24 ttl=64 time=12.195 ms
64 bytes from 192.168.0.1: icmp_seq=25 ttl=64 time=12.695 ms
64 bytes from 192.168.0.1: icmp_seq=26 ttl=64 time=18.840 ms
64 bytes from 192.168.0.1: icmp_seq=27 ttl=64 time=5.331 ms
64 bytes from 192.168.0.1: icmp_seq=28 ttl=64 time=15.378 msThis is with everthing online.
