LVnewbie
Apr 08, 2018Aspirant
Orbi Experience - (RBK50) AC3000
Hi I have just set up the Orbi system and so far so good but wondering if the solid blue light which shows good connection that is on the satelitte should stay on all the time or does it just ini...
LVnewbie
And is there an option to set up orbi with different "channels" such as the 2.4 or 5 Ghz so you can select appropriatefor device?
thank you, i appreciate any help to achieve the optimum usage out of this awesome technology!
