LVnewbie
Apr 08, 2018Aspirant
Orbi Experience - (RBK50) AC3000
Hi I have just set up the Orbi system and so far so good but wondering if the solid blue light which shows good connection that is on the satelitte should stay on all the time or does it just ini...
Apr 08, 2018Guru - Experienced User
The Blue LED should be in for a short period of time then turn OFF. OFF means all is working.
You can change channels for both radios. Found in the routers web page.
What FW version is the Orbi using?
