Brenkj
Apr 26, 2019Aspirant
Orbi extender for patio
I recently got an Orbi system. It works great indoors, but the WiFi on my patio is really weak. Is there a small extender I can get for that? Thanks
CrimpOn
Apr 27, 2019Guru - Experienced User
I agree with michaelkenward If the signal is not good on the patio now, adding an expensive weatherproof external satellite would not be my first choice. (Unless the patio is located away from the building) I would look for a location inside the house that is close to the patio and has at least a moderate 5G signal from the router or other internal satellite. My Orbi's project a strong (5-bar" signal through the wall and onto my front porch and rear patios. I, personally, am leery of the "wall plug" satellites, because the design screams out "plug me in at the bottom of the wall behind furniture and other obstacles." Not having ever purchased one, my concerns are entirely superstition.
- michaelkenwardApr 27, 2019Guru - Experienced User
CrimpOn wrote:
I, personally, am leery of the "wall plug" satellites, because the design screams out "plug me in at the bottom of the wall behind furniture and other obstacles."Good thinking, but there is a way around that.
If you have two floors, put the plug-in satellite at ground level upstairs. Then it is at floor level and is well positioned to deliver wifi to both levels upstairs and downstairs.
That works for me.
