Brorob
Dec 29, 2020Aspirant
Orbi extremely unstable
Have had an Orbi RBR 50 since 2017 with a base router on the first floor and satellite on the second floor and for the most part it has worked well. Occasionally have to reboot and synch the upstair...
Dec 29, 2020Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
You can find other speed diagnosis steps in the community faq: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-t-my/m-p/1982974/highlight/true#M7849
- vajimDec 29, 2020Master
:smileysad:
- BrorobJan 01, 2021Aspirant
I am not able to login into the router so can't tell what version of firmware is running or make any changes suggested. I've tried different browsers, different computers, using the orbi app on my phone with no luck. The light of the router is on, but tracking the wifi through a speed test app on my phone, wifi will be on and connected for 30 seconds to a little more than a minute and then will disconnect for a few seconds to 30 seconds, before the device connects again. LIght on top of the router stays on the whole time and doesn't change. System is on channel 8 and 48, but can't access the router to change channels. The Net gear wifi analyzer shows only our router on channel 8 and then overlaps on channel 48. Same result if satellite is on or off. satellite is on seond floor, close to 30 feet away. worked fine for 3 years so am not sure what changed.
- vajimJan 01, 2021Master
If you can not login to the router using a browser, I would factory reset the entire system. This sounds like it qualifies.
