Brorob
Dec 29, 2020Aspirant
Orbi extremely unstable
Have had an Orbi RBR 50 since 2017 with a base router on the first floor and satellite on the second floor and for the most part it has worked well. Occasionally have to reboot and synch the upstair...
Dec 31, 2020Guru - Experienced User
Any progress on this?
Brorob wrote:Have had an Orbi RBR 50 since 2017 with a base router on the first floor and satellite on the second floor and for the most part it has worked well. Occasionally have to reboot and synch the upstairs satellite. A couple of days ago, home WIFI became very unstable with service fluctuating almost by the minute- with it working for a minute and then not working. I've rebooted and reset several times with no change. I downloaded the Netgear WIFI analytics app and can see the signal strength fluctuate from a -30db to a -100db. the change is so fast that I am not able to log into the router to upload software. Any thoughts or suggestions? thanks
