AUnet
Mar 11, 2017Tutor
Orbi Facetime lag issue
I'm having issue while using Facetime on Orbi RBR50 wifi. It's reconnecting every 10-20 seconds. When I switch over to cell network for the same Factime, it's working just fime. Anyone aware of this...
- Mar 24, 2017
Hello 8380
There are disconnect issues on IOS that the engineers are working on you would try to lower the power level of the 2.4ghz network in the Advanced wireless settings some people have said this makes a more stable connection for IOS devices.
DarrenM
DarrenM
Mar 16, 2017Sr. NETGEAR Moderator
Hello Aunet
is this happening when you are on the sattellite or the main router or both?
DarrenM
