AUnet
Mar 11, 2017Tutor
Orbi Facetime lag issue
I'm having issue while using Facetime on Orbi RBR50 wifi. It's reconnecting every 10-20 seconds. When I switch over to cell network for the same Factime, it's working just fime. Anyone aware of this...
- Mar 24, 2017
Hello 8380
There are disconnect issues on IOS that the engineers are working on you would try to lower the power level of the 2.4ghz network in the Advanced wireless settings some people have said this makes a more stable connection for IOS devices.
DarrenM
8380
Mar 22, 2017Aspirant
I am expereincing the same issues. Just switched from Linksys in hopes of toublefree wifi, this is very concerning. NetGear tech support help!
DarrenM
Mar 24, 2017Sr. NETGEAR Moderator
Hello 8380
DarrenM
- 8380Mar 24, 2017Aspirant
Darren that fixed it. I tried many other settings but didn't think that the power level would matter. Thank you very much!!
