siuolly
Dec 22, 2017Star
Orbi failed and needs to reset to factory settings every two weeks
I bought my Orbi + 1 satelite around Feb 2017. My router was from my ISP the Hitron CODA 4582 and the Orbi is in AP mode. Works fine after setup for 2 weeks. Every two weeks, there's no internet c...
Kalzone
Jan 03, 2018Aspirant
I am having the same issue. We’re you able to get it resolved?
siuolly
Jan 04, 2018Star
The work around is when I put my router to AP mode, use static IP instead of dynamic. After servers days the magenta light still come on (meaning router can not obtain IP) but my internet works fine. At least I don’t have to reset it.
- darrenw2112May 15, 2018Aspirant
I have my orbi setup as normal and I still have to reset the wifi often (wired continues to work). All firmware up to date.
- FURRYe38May 15, 2018Guru - Experienced User
What channels are you using?
What ISP mfr and model# modem do you have connected to the Orbi router?
Any wifi neighbors near by? If so, how many?
Try manual channel 1, 6 or 11 on 2.4ghz and any unused channel on 5Ghz.
Disable MIMO, Daisy Chain and Fast Roaming and see how this does for you.
What is the distance between the router and satellite?
