Rnubes
Dec 30, 2018Aspirant
ORBI FAILS TO BACKHAUL WITH CONNECTED DEVICES RBK50
After extensive research i got the ORBI RBK50 with one satellite. I choose it due to ethernet backhaul. After a successful setup, i plugged the ethernet into it for the backhaul. First right next to ...
Dec 30, 2018Guru - Experienced User
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually. This feature needs to be disabled if you connect the satellite via ethernet to the base router.
Set up IP address reservations for each satellite and devices on the router as you add them to the router. The satellites need to be set up via wireless first. Then connect 1 satellite at a time to the ethernet LAN cable. Wait 5 minutes and the top led on the satellite should turn on BLUE. Set up an IP address reservation for the 1st satellite. Continue to do the same thing for the 2nd satellite. Then follow up with your devices.
- RnubesDec 31, 2018AspirantThanks. Got it working using that. But I notice the phone app just shows everything connected to the router as it says the satellite is not connected . When I log into satellite I can see the devices attached. Seems the phone app doesn’t accurately show the devices connected?
- FURRYe38Dec 31, 2018Guru - Experienced User
Yes. It's working. When the satellite is connected wired to the router, the device connects show up as connected to the router since the connect is directly in contact with the router. If the satellite was wireless, it would show up as connected to the satellite.
