jpottaway
Jun 13, 2020Tutor
Orbi failure 2 months out of 2 year warranty
WAN port does not pickup Internet any more. Reset, restart etc, nothing. Just says "no cable connected". Swapping to another router it works fine. Really annoyed as I expected this very expensive...
Jul 06, 2020Guru - Experienced User
Did you swap LAN cable between modem and RBR?
Did you power OFF the modem for 1 minuted then back ON then factory reset the RBR and walk thru the setup wizard to see if it detected the internet?
