JMU1998
Nov 25, 2016Luminary
Orbi Firmware 1.4.0.16
Looks like new Firmware just released today 1.4.0.16 anyone taken this yet? I will as soon as I get some time today hopefully it address frequent random wireless drops.
- Looks like they have enabled Guest network access.
- An "add orbi satellite"option
Not seeing much else that I can tell.
- dpdurstLuminary
Yep just upgraded, guest network access is now available that is the first thing that stands out along with adding another Orbi satellite to the system.
Under advanced wireless settings, I don't recall the wireless stuff and resetting the backhaul password to be there before was it?
i assume you guys got this via auto update ? as its not on the web site as yet
- dpdurstLuminary
Yes
- Dave_G20Aspirant
I am looking for an image file for the RBS50 for the 1.4.0.16 update (Just got the thing). The RBK router updated to 1.4.0.16 and the satellite is an epic fail (won't update from the stock 1.1.0.16 version). The firmware link on the site is just the 1.3 version leaving me high and dry. Any idea where I can 1.4 for the RBS?
hi
you need to update the sat/s to 1.3 first and then it should then show you the 1.4 software available for the sats
The release notes for the new FW
Release Notes:
[New Features] Support Guest WiFi network.
[New Features] Support WiFi signal broadcast scheduling.
[Enhancements] Add-on Orbi satellite installation flow in GUI.
[Enhancements] Wireless region support for Japan.
[Enhancements] Internet speed test via Ookla SpeedTest.
[Enhancements] Improves band steering.
[Bug Fixed] Fixes connectivity issue with Xbox and iOS devices.
[Bug Fixed] Fixes some security issues.
[Bug Fixed] Fixes Orbi online firmware upgrade issue.
[Bug Fixed] Fixes Orbi satellite's manual firmware update issue.
[Bug Fixed] Fixes GUI display issues in Attached Devices and Access Control pages.- Anyone else having a few issues?
I have a wired device on my satellite that does not show up on attached devices, but it is getting to the internet.
Access Control I have 3 devices that are showing blocked and I can not get them to be allowed. I choose to allow them and they still come back as blocked. - GadgetGuyApprenticeJust upgraded my system and guest network is working. Thanks Netgear for listening to us.
Easy setup. Did the upgrade sitting in the couch from my iPhone.- itsmedrew2Aspirant
It shows that there is an update, but does not allow me to update. Can't even do the update manually as it is not available for download yet from the site. Any advice?
- Dan4th1InitiateI received my Orbi yesterday. Satellite would not connect unless sitting next to the router. I downloaded the firmware updates and it works great. Just kinda ticked they sent them to me with the original firmware installed. Auto download wouldn't work either. Had to go to Netgear website and manually download and install. For $400 they should be working when they arrive!
- JMU1998Luminary
Your orbi was manufactured and packaged in placed in inventory before new fw was released that is why you have the option to download latest.... when you buy a new computer does it not update? when you get a new phone does it not update? same scenario here.
Dan4th1 wrote:
I received my Orbi yesterday. Satellite would not connect unless sitting next to the router. I downloaded the firmware updates and it works great. Just kinda ticked they sent them to me with the original firmware installed. Auto download wouldn't work either. Had to go to Netgear website and manually download and install. For $400 they should be working when they arrive!seeing as you dont buy the orbi direct from netgear the state of the firmware will depend on when the supplier got their shipment as to what level fw it will have , dont forget the orbi has come a long way in a very short space of time both hardware and firmware wise
the autoupdate feature was a bit problematic in some early fw and is why you had to manually update it but from now on any new releases will appear in the web gui when you login and prob update for you behind the scenes , me i would prefer if you could tick a box to not have it do it automatically and instead choose when its done but that just my geek side not liking big brother messing with my stuff
i have had this fw for a while now and for the most part its working fine here , kids are happy wifi is happy so im happy
hopefully this release will fix some issue that have been reported on this forum and the experience is a better one for everyone now that guest wifi is available as it was one of the biggest gripes ppl had about features missing in the orbi
other features like ethernet backhaul i cant see anytime soon , however seeing as the firmware is basically open source you might find someone taking interest in developing 3rd party firmware that may in time allow such other features , its not like the orbi is short of ram
anything is possible and thanks for the netgear dev team for getting the fw and guest wifi out in a timely manner
what needs to be acknowledged is how far the orbi has come in such a short period of time esp being a new class and type of technology not seen in this form before so no prior knowledge to base it on , it was only 6 months ago that the orbi started its beta trials and now its main line and working well in the wild , in tech terms thats pretty dam quick
pete
- AniDuttaApprenticeOrbi rocks! On a side note,Costco is selling a 3- pack ( 1 router and 2 Sat) for $500. Cheaper for those who will need an additional satellite.
- I'm concerned the new firmware update has bottlenecked my Orbi network. Before I was getting 90-170mbps since the update. I'm barely seeing 10-25mbps. Has anyone else witness this? I've rebooted. I assumed my network switch was incompatible so I unplugged it and immediately saw my original speeds come back, but minutes later goes back to the same slower speeds. I'm wondering should I factory reset with the new firmware and see how that works.
I'm seeing the same thing, randye, but only on the satellite. Previous download speeds ~230mbps just now anywhere from there to ~130. Different tests are all over the place. Maybe too many black Friday shoppers!
I'm making a guess that the band steering enhancement is possibly my issue. There was a thread or post stating that Orbi has a problem switching from 2.4Ghz to 5Ghz and vice versa when a device is near a stronger/weaker signal.
I saw none of these low speeds until the new firmware arrived.
- randye I have not seen this issue since I upgraded yesterday. I am setting my full bandwidth of 100mb. I also have tested my HTPC write connected (2gb trunk) to the satellite and my laptop on wireless and I get about max of 300-350mbs.
- Pesto242 how do you disable band steering?
