JMU1998
Nov 25, 2016Luminary
Orbi Firmware 1.4.0.16
Looks like new Firmware just released today 1.4.0.16 anyone taken this yet? I will as soon as I get some time today hopefully it address frequent random wireless drops.
- XBondApprenticeI never disabled those options and I just confirmed that both options are enabled.
XBond wrote:
I never disabled those options and I just confirmed that both options are enabled.they are disabled by default on new firmware , so you ether havnt updated the firmware or at some point you have enabled those options
i also recommend setting the 2.4 gig ch to something other that auto , ether ch 1 , 6 or 11
they have also played around with various tweaks in the transmission in this latest fw revision so the balance may be different and thus why you are now connecting to the router instead of the sat
- XBondApprenticeNot sure what to tell you, but I do have the latest firmware, I never enabled those options myself, and they are enabled. đ For real...
But the most important thing is that although I am connected to the satellite now, I am getting the speed I expect (i.e. connected to the 5GHz band).
Just curious, why change the 2.4 channel?- spiffyAspirant
This link from Wikipedia explains it pretty well. You can pretty much get it just from the diagram, but the text adds some detail.
https://en.wikipedia.org/wiki/List_of_WLAN_channels#2.4.C2.A0GHz_.28802.11b.2Fg.2Fn.29
To add to that, my understanding is that in a *very* crowded environment (where you live in an apartment and you might see 20 other people using each of those channels) it can still make sense to choose something different, but in a typical environment (where you might see 1 or two other people using the same channel as you) it's still best to pick one of those.
FYI there's a great app for Android (no idea if it exists for iOS or not) called "Wifi Analyzer" which will graphically show you what SSIDs are visible on what channels at your location, and their relative strengths.
