PhoenixV
Mar 18, 2017Apprentice
Orbi Firmware 1.8.06 dropping WiFi Calling calls
I am having an issue with the latest firmware 1.8.06 dropping WiFi Calling calls made from my cell phone. Is anyone else experiencing this issue? This problem did not happen with the previous version...
Retired_Member
Mar 18, 2017Like I said the connection has to be very stable. I have worked in IT for 25 years and know how voip systems work. You can believe what you want but unless your connect is solid you will have issues. Again you won't notice the drops without using special tools if it's just not showing your bars dropping.
