LarryinNJ's avatar
Dec 30, 2017
Orbi Firmware 2.0.0.56 vs 2.1.1.12
Got the Orbi system from Black Friday and just set it up. Setup did a firmware update from 1.x  to 2.0.0.56. Auto update says no further updates are available. Website shows 2.1.1.12 for the RBR-40 router, and 2.1.1.18 for the RBW-30 sats.
Performance has been pretty good, one of the sats has disconnected a couple of times in a week. Orbi app speedtest shows stated throughput (200down/35 up), while regular speedtest app is all over the map on downloads (10-150 down).
Thoughts on on doing a manual update for added stability, and if so, what is the best method (router or sats first, when to reset to factory defaults, etc.)
1 Reply
  • Being that some of the currently released firmware seems to be causing issues to some customers I would advise you to just leave it alone, if the router says nothing is available, leave it alone for now.
