gassynizz
Apr 27, 2019Aspirant
Orbi Firmware 2.3.1.48 Breaks Daisy Chain Functionality
Previously excellent daisy chain backhaul from one RBS50 to an RBS20 was rendered nonfunctional by the updated firmware, from*44 to the latest *48. Correct steps were followed in the firmware updat...
Apr 29, 2019Guru - Experienced User
Try giving more time to the setup and process.
Try a factory reset and setup from scratch.
Others are working with v48 FW.
gassynizz
Apr 30, 2019Aspirant
I appreciate the above replies, and also tried all the steps offered as possible solutions prior to rolling back firmware to *.44 and nothing short of the firmware rollback worked.
Perhaps there is something specific about using an RBR50 to RBS50 with daisy chain backhaul to RBS20 that doesn’t work in my particular configuration with *.48.
- FURRYe38Apr 30, 2019Guru - Experienced User
Well the RBS20 is a lower connection rated satellite where the 50 series rates at 1700Mb on it's wireless back haul. The 20 series come in at 868Mb. Not sure if this would effect how daisy chain works or not. Would have to find another RBS50 to test it out. Even though 20 and 50 series are supported, it's best to keep the same rating satellites for best operation.
