gassynizz
Apr 27, 2019Aspirant
Orbi Firmware 2.3.1.48 Breaks Daisy Chain Functionality
Previously excellent daisy chain backhaul from one RBS50 to an RBS20 was rendered nonfunctional by the updated firmware, from*44 to the latest *48. Correct steps were followed in the firmware updat...
SW_
Apr 30, 2019Prodigy
gassynizz wrote:
Correct steps were followed in the firmware update process, gear was power cycled, distant rbs20 was later restarted after rbr50 and rbs50’s were up and running, and rbs20 would still only connect to router.
If Daisy-Chain is enabled on the Router and not enabled on the Satellite, it might explain this behavior. Points your browser to Satellite-IP-Address/debug.htm and check its daisy chain status. There should be a grey check box next to it.
If the box is not ticked, try these:
1. telnet into the Satellite
2. config default
3. config commit
4. reboot
That will instruct the Satellite to refresh its Daisy-Chain setting along with all other settings from the main Orbi Router.
