ReallyAnnoyedAF
May 02, 2019Star
Orbi Firmware 2.3.1.60
Welp, anyone have any notes on this thing? It's already downloaded to my router and satellite waiting for me to pull the pin.
- May 03, 2019
Hi,
Just for information, when you're in the Firmware Update page and it downloads new firmware to install, the version number next to both the router and the satellite is a clickable link.
If you click the link, it will show you the release notes of all changes between your currently installed firmware and the update.
Although, this "feature" is not hidden, it's not always obvious that it's there either.
May 02, 2019Guru - Experienced User
What model Orbi do you have? 20, 30, 40 or 50 series?
I nothing posted as of yet for this version of FW.
- ReallyAnnoyedAFMay 02, 2019Star
RBR50/RBS50 - not listed in the Model selection field.
- FURRYe38May 02, 2019Guru - Experienced User
Keep checking the download web site for posted release notes...if your system is running with out any problems, I'd hold off for now.
SOP.
