ReallyAnnoyedAF
May 02, 2019Star
Orbi Firmware 2.3.1.60
Welp, anyone have any notes on this thing? It's already downloaded to my router and satellite waiting for me to pull the pin.
- May 03, 2019
Hi,
Just for information, when you're in the Firmware Update page and it downloads new firmware to install, the version number next to both the router and the satellite is a clickable link.
If you click the link, it will show you the release notes of all changes between your currently installed firmware and the update.
Although, this "feature" is not hidden, it's not always obvious that it's there either.
ReallyAnnoyedAF
May 02, 2019Star
RBR50/RBS50 - not listed in the Model selection field.
May 02, 2019Guru - Experienced User
Keep checking the download web site for posted release notes...if your system is running with out any problems, I'd hold off for now.
- ReallyAnnoyedAFMay 02, 2019Star
SOP.
- FURRYe38May 02, 2019Guru - Experienced User
:smileywink:
- OverlandrMay 02, 2019Aspirant
I just pulled the pin. 2 hrs in - rock solid so far.
- Blanca_OMay 06, 2019NETGEAR Employee Retired
The firmware 2.3.1.60 has the following changes :
Fixes the issue where the time zone can't sync with the satellite
Fixes issues with the guest network control using Alexa
Includes security fixes
- JMU1998May 06, 2019Luminary
After updating to. 60 now my sattalite shows up as connected as a 5g eventhough it has an Ethernet cable plugged in connected to my network. Did factory reset on both sattalite and main unit running in AP mode. Anyone else seeing the sattalite showing as 5g instead of wired for those using wired backhaul and did latest update?
