ReallyAnnoyedAF
May 02, 2019Star
Orbi Firmware 2.3.1.60
Welp, anyone have any notes on this thing? It's already downloaded to my router and satellite waiting for me to pull the pin.
- May 03, 2019
Hi,
Just for information, when you're in the Firmware Update page and it downloads new firmware to install, the version number next to both the router and the satellite is a clickable link.
If you click the link, it will show you the release notes of all changes between your currently installed firmware and the update.
Although, this "feature" is not hidden, it's not always obvious that it's there either.
totallykevin
May 02, 2019Initiate
welp.. after the firmware update 3 drops in my network within the last 3 hours. Whyyyyy did i do it?!
- SW_May 02, 2019Prodigy
After hitting the "Update All" button, everything came back online in ~10mins.
Orbi/Satellites Backhaul Status looks good:
root@RBR50:/# wlanconfig ath2 list
- ADDR AID CHAN TXRATE RXRATE RSSI ...
- 14:59:c0:3b:e7:xx 1 157 1170M 1170M 35 ...
- 14:59:c0:3b:e1:xx 2 157 1300M 1300M 40 ...
root@RBR50:/# cat /tmp/satellite_device_info
"signal strength": "-55",
"current version": "V2.3.1.60",
"backhaul status": "2",
"device name": "Orbi Satellite-1"
"signal strength": "-60",
"device name": "Orbi Satellite-2"
Backhaul Signal Strength between ORBI and its 2 Satellites:
- 40 - 95 = -55 dBm, Backhaul Link Speed 1300M
- 35 - 95 = -60 dBm, Backhaul Link Speed 1170M
- Dd852May 03, 2019Luminary
Even with telnet enabled, I'm now unable to telnet in when I could before. Clearly nothing changed for you! Strange... I simply get an error
[Could not create a new process and open a pseudo-tty.]
I'm on Apple Macos 10.14.4 - perhaps apple has made it impossible in its updating. Anyone have success with an apple?
- MikeG63May 03, 2019Apprentice
I am running MacOS Mojave 10.14.4 and I am not experiencing any issues or difficulties.
