ReallyAnnoyedAF
May 02, 2019Star
Orbi Firmware 2.3.1.60
Welp, anyone have any notes on this thing? It's already downloaded to my router and satellite waiting for me to pull the pin.
- May 03, 2019
Hi,
Just for information, when you're in the Firmware Update page and it downloads new firmware to install, the version number next to both the router and the satellite is a clickable link.
If you click the link, it will show you the release notes of all changes between your currently installed firmware and the update.
Although, this "feature" is not hidden, it's not always obvious that it's there either.
iSuresh
May 05, 2019Tutor
My RBR50 updated to .60 without any issues but my RBS50 is stuck on .48. It shows "Waiting for connection" on the firmware update page.
Rebooted twice, no luck. Any suggestions to get my sattelite also updated to .60? I do not see any firmware downloads links for manual update.
- michaelkenwardMay 05, 2019Guru - Experienced User
Maybe there isn't one. They don't always go side by side, especially for satellites.
- SW_May 05, 2019Prodigy
Satellites pull their Wireless Settings from the main Router. If there's a misconfigured Wireless setting or any setting for that matter, it will affect all Satellites. Otherwise, common wireless issue is often traced back to the main Router settings unless there's an issue like hardware failure specific that one Satellite, stale configs were still stuck in NVRAM, which requires reset to clear, or weak Backhaul between Satellites/Router.
I would be very interest in any special config that's only configurable via Satellite. That would be nice to know as well. :-)
Not quite sure what you are looking for here, but the RBS50Y Outdoor Satellite and RBS40V Voice are two satellites that do wonky things.
The Outdoor Satellite certainly has wifi controls that are unique to its interface. The indoor/outdoor thing is something to do with the law.
As yet, no 2.3.1.60 on the RBR40.
- gr8shoMay 08, 2019Virtuoso
Although most have probably figured this out by now, the RBS50 does indeed have a .60 update. Cheers.
- MikeG63May 05, 2019Apprentice
I had that exact same problem. I cycled the power on my 'errant' satellite which resulted in it then correctly showing the required firmware update. I then did a manual update and just selected that particulare satellite. Then all was fine.
Message 69 of 73- MikeG63May 05, 2019Apprentice
A couple of question if I may
- Does re-booting the router also re-boot the satellites?
- Also is there a way to re-boot individual satellites?
Thanks
Thanks
1. No.
2. Yes, need to enable telnet, then telnet into each Satellite/Router and type "reboot"
Check out this link for telnet and related info.
