ReallyAnnoyedAF
May 02, 2019Star
Orbi Firmware 2.3.1.60
Welp, anyone have any notes on this thing? It's already downloaded to my router and satellite waiting for me to pull the pin.
- May 03, 2019
Hi,
Just for information, when you're in the Firmware Update page and it downloads new firmware to install, the version number next to both the router and the satellite is a clickable link.
If you click the link, it will show you the release notes of all changes between your currently installed firmware and the update.
Although, this "feature" is not hidden, it's not always obvious that it's there either.
MikeG63
May 05, 2019Apprentice
I had that exact same problem. I cycled the power on my 'errant' satellite which resulted in it then correctly showing the required firmware update. I then did a manual update and just selected that particulare satellite. Then all was fine.
iSuresh wrote:
My RBR50 updated to .60 without any issues but my RBS50 is stuck on .48. It shows "Waiting for connection" on the firmware update page.
Rebooted twice, no luck. Any suggestions to get my sattelite also updated to .60? I do not see any firmware downloads links for manual update.
Message 69 of 73
MikeG63
A couple of question if I may
- Does re-booting the router also re-boot the satellites?
- Also is there a way to re-boot individual satellites?
Thanks
- SW_May 05, 2019Prodigy
Thanks
1. No.
2. Yes, need to enable telnet, then telnet into each Satellite/Router and type "reboot"
Check out this link for telnet and related info.
