ReallyAnnoyedAF
May 02, 2019Star
Orbi Firmware 2.3.1.60
Welp, anyone have any notes on this thing? It's already downloaded to my router and satellite waiting for me to pull the pin.
- May 03, 2019
Hi,
Just for information, when you're in the Firmware Update page and it downloads new firmware to install, the version number next to both the router and the satellite is a clickable link.
If you click the link, it will show you the release notes of all changes between your currently installed firmware and the update.
Although, this "feature" is not hidden, it's not always obvious that it's there either.
jweise
May 05, 2019Apprentice
- Tried going to long preamble mode and the result was that my internet speed was cut ion half!
SW_
May 05, 2019Prodigy
Did you have WiFi drop before/after as a result of this test?
WiFi speed drop is expected with Long because there's more overhead to transmit, which is the reason for Short. It's a trade off between performance and reliability. GIven you have WiFi speed lost, have you disabled 2.4Ghz co-existent?
