ReallyAnnoyedAF
May 02, 2019Star
Orbi Firmware 2.3.1.60
Welp, anyone have any notes on this thing? It's already downloaded to my router and satellite waiting for me to pull the pin.
- May 03, 2019
Hi,
Just for information, when you're in the Firmware Update page and it downloads new firmware to install, the version number next to both the router and the satellite is a clickable link.
If you click the link, it will show you the release notes of all changes between your currently installed firmware and the update.
Although, this "feature" is not hidden, it's not always obvious that it's there either.
Pedro_mustard
May 06, 2019Aspirant
Both my RBR50 and RBS50 want to download the latest firmware and have never been able to and TBH it's quite annoying.
- FURRYe38May 06, 2019Guru - Experienced User
What is the Mfr and model# of the ISP modem the NG router is connected too?Can you select the RBS first to update?
What browser are you using?
- gr8shoMay 06, 2019VirtuosoIf I saw something not working that's supposed to work, it would probably lead me down a road that some here refer to as the "nuclear option", which is to grab a paperclip and perform a full factory reset. The problem is unlikely to fix itself, unless of course the servers are temporarily unavailable. However, I just checked and I do see v60 is offered on the Firmware Update page.
