ReallyAnnoyedAF
May 02, 2019Star
Orbi Firmware 2.3.1.60
Welp, anyone have any notes on this thing? It's already downloaded to my router and satellite waiting for me to pull the pin.
- May 03, 2019
Hi,
Just for information, when you're in the Firmware Update page and it downloads new firmware to install, the version number next to both the router and the satellite is a clickable link.
If you click the link, it will show you the release notes of all changes between your currently installed firmware and the update.
Although, this "feature" is not hidden, it's not always obvious that it's there either.
swall101
May 06, 2019Aspirant
Really don’t know what all the drama is. I logged into the app, it said update available, downloaded and installed firmware, Orbi works just as awesome as it always has. Bravo Netgear....
gr8sho
May 06, 2019Virtuoso
You're just not reading enough to find the drama in the forum. :P
- Pedro_mustardMay 06, 2019Aspirant
2.3.1.48 is the version on both RBR50 and RBS50
- FURRYe38May 06, 2019Guru - Experienced User
Should be good to update to v60. Unless there is a NG service issue.
Did you update to v48 using same process before?
Can you select the RBS first to update?
What browser are you using?
